メインコンテンツにスキップ
Canon PowerShot S80 Motherboard Replacement
必要な工具と部品
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: 手順 1、 2の画像 1 Canon PowerShot S80 Motherboard Replacement, Outer Casing: 手順 1、 2の画像 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: 手順 2、 2の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 2、 2の画像 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: 手順 3、 3の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 3、 3の画像 2 Canon PowerShot S80 Motherboard Replacement: 手順 3、 3の画像 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: 手順 4、 3の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 4、 3の画像 2 Canon PowerShot S80 Motherboard Replacement: 手順 4、 3の画像 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: 手順 5、 1の画像 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: 手順 6、 2の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 6、 2の画像 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: 手順 7、 1の画像 1
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: 手順 8、 1の画像 1
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: 手順 9、 1の画像 1
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: 手順 10、 3の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 10、 3の画像 2 Canon PowerShot S80 Motherboard Replacement: 手順 10、 3の画像 3
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: 手順 11、 2の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 11、 2の画像 2
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: 手順 12、 2の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 12、 2の画像 2
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: 手順 13、 2の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 13、 2の画像 2
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: 手順 14、 1の画像 1
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: 手順 15、 3の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 15、 3の画像 2 Canon PowerShot S80 Motherboard Replacement: 手順 15、 3の画像 3
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: 手順 16、 1の画像 1
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: 手順 17、 1の画像 1
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: 手順 18、 2の画像 1 Canon PowerShot S80 Motherboard Replacement: 手順 18、 2の画像 2
    • Use a spudger to gently lift the motherboard from the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
BrettH
メンバー登録日: 10/28/09
219 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012人のメンバー
CPSU-MANESS-SU12S19G5
1 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 4,510
