この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The LCD screen of the Canon PowerShot S80 is necessary for the normal operation of the camera. The screen is also vulnerable to cracks, chips and water damage. This guide will walk you through replacing your LCD screen and saving your camera.
必要な工具と部品
Remove the three screws that are holding the screen in place and free the screen from the underlying components.
3 の人々がこのガイドを完成させました。
2 件のコメント
I presume the narrow ribbon cable supplies power to the backlight behind the screen? I replaced the combined screen and backlight assembly. I now have an image but it is extremely dark, barely visible. Perhaps the backlight didn't come on?
The contacts on both the wide ribbon and the narrow ribbon were corroded, probably the source of the problem.
Any suggestions?
I found very easy to follow the instructions provided. I just commenta that the last step should be completed by the separation between the screen and the support plate, which is not shown. However if one reaches that point (having the replacement part at hands) it has easy to find the next step of the “surgery”.
Goodinstruction. Thanks to this I brought to new life my Canon Powrr shot S80
