メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The LCD screen of the Canon PowerShot S80 is necessary for the normal operation of the camera. The screen is also vulnerable to cracks, chips and water damage. This guide will walk you through replacing your LCD screen and saving your camera.
パーツ
パーツは指定されていません。
  1. Remove the knot on the wrist lanyard. Remove the battery and memory card.
    • Remove the knot on the wrist lanyard.
    • Remove the battery and memory card.
  2. Remove all screws from sides of outer casing. Begin removing the screws on the bottom of the outer casing.
    • Remove all screws from sides of outer casing.
    • Begin removing the screws on the bottom of the outer casing.
    • Remove the rest of the screws from the outer casing.
  3. Gently pull the front cover off the camera. Gently pull the front cover off the camera. Gently pull the front cover off the camera.
    • Gently pull the front cover off the camera.
  4. Open the "A/V Out Digital" cover slide, and remove the screw inside. Gently pull off the back casing. Remove the black "L" shaped piece of metal.
    • Open the "A/V Out Digital" cover slide, and remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Remove the three screws that are holding the screen in place and free the screen from the underlying components.
    • Remove the three screws that are holding the screen in place and free the screen from the underlying components.
    • Be careful of the ribbon wire that is still attached on the left of the screen.
  6. With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place. Unplug the wide ribbon cable.
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body
    The author failed to mention a couple things. First, the screen is in a holder which you remove, then after pulling off some electrical tape, you have to yank the actual screen out. Second, I only had two screws to pull the screen holder out, not three. Third, the thing that you have to pull to get the screen ribbon cable out is actually a tiny black hinge, so don't worry if it suddenly snaps back. Finally, to put the thing back together, it really helps if you have a tweezers to get the ribbon cables back into place.
    and fyi replacement screens available from canon parts department for about 50 bucks.
    steven - 返信
終わりに
3 の人々がこのガイドを完成させました。
BrettH
メンバー登録日: 2009年10月28日
219 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012人のメンバー
CPSU-MANESS-SU12S19G5
1 メンバー
5のガイドは作成済み
2 件のコメント
I presume the narrow ribbon cable supplies power to the backlight behind the screen? I replaced the combined screen and backlight assembly. I now have an image but it is extremely dark, barely visible. Perhaps the backlight didn't come on?
The contacts on both the wide ribbon and the narrow ribbon were corroded, probably the source of the problem.
Any suggestions?
Clive Williams - 返信
I found very easy to follow the instructions provided. I just commenta that the last step should be completed by the separation between the screen and the support plate, which is not shown. However if one reaches that point (having the replacement part at hands) it has easy to find the next step of the “surgery”.
Goodinstruction. Thanks to this I brought to new life my Canon Powrr shot S80
attilio.brighenti - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 6,998
