Begin removing the screws on the bottom of the outer casing.
Next, remove the rest of the screws from the outer casing.
Open the "A/V Out Digital" cover. Remove the screw inside.
Gently pull off the back casing.
Remove the black "L" shaped piece of metal.
With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
Unplug the wide ribbon cable.
Unplug the narrow ribbon cable to free the LCD screen from the camera body.
Remove the cable connection. With a metal spudger, gently pry up.
Remove the ribon cable. With a metal spudger, gently lift up the black tab.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
