メインコンテンツにスキップ
Canon PowerShot S80 Flash Replacement
必要な工具と部品
  1. Canon PowerShot S80 Flash Replacement, Outer Casing: 手順 1、 2の画像 1 Canon PowerShot S80 Flash Replacement, Outer Casing: 手順 1、 2の画像 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Flash Replacement: 手順 2、 2の画像 1 Canon PowerShot S80 Flash Replacement: 手順 2、 2の画像 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Flash Replacement: 手順 3、 3の画像 1 Canon PowerShot S80 Flash Replacement: 手順 3、 3の画像 2 Canon PowerShot S80 Flash Replacement: 手順 3、 3の画像 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Flash Replacement: 手順 4、 3の画像 1 Canon PowerShot S80 Flash Replacement: 手順 4、 3の画像 2 Canon PowerShot S80 Flash Replacement: 手順 4、 3の画像 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: 手順 5、 1の画像 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Flash Replacement: 手順 6、 2の画像 1 Canon PowerShot S80 Flash Replacement: 手順 6、 2の画像 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Flash Replacement, Flash: 手順 7、 1の画像 1
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Canon PowerShot S80 Flash Replacement: 手順 8、 2の画像 1 Canon PowerShot S80 Flash Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. Canon PowerShot S80 Flash Replacement: 手順 9、 1の画像 1
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. Canon PowerShot S80 Flash Replacement: 手順 10、 1の画像 1
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Canon PowerShot S80 Flash Replacement: 手順 11、 1の画像 1
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Canon PowerShot S80 Flash Replacement: 手順 12、 1の画像 1
    • Lift the flash bulb unit upwards from the camera.
  13. Canon PowerShot S80 Flash Replacement: 手順 13、 2の画像 1 Canon PowerShot S80 Flash Replacement: 手順 13、 2の画像 2
    • Lift the entire three-part flash assembly from the camera.
終わりに
作成者
7人の作成者と共同で作成されました。
BrettH
メンバー登録日: 10/28/09
219 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 19-5, Maness SU 2012 Cal Poly, Team 19-5, Maness SU 2012人のメンバー
CPSU-MANESS-SU12S19G5
1 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 3,698
