メインコンテンツにスキップ
Canon PowerShot S50 Front Panel/Battery Door Replacement
必要な工具と部品
  1. Canon PowerShot S50 Front Panel/Battery Door Replacement, Battery: 手順 1、 2の画像 1 Canon PowerShot S50 Front Panel/Battery Door Replacement, Battery: 手順 1、 2の画像 2
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 2、 1の画像 1
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 3、 2の画像 1 Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 3、 2の画像 2
    • Holding the edges, slide out the battery.
  4. Canon PowerShot S50 Front Panel/Battery Door Replacement, Front Panel/Battery Door: 手順 4、 1の画像 1
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 5、 1の画像 1
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 6、 1の画像 1
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 7、 1の画像 1
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 8、 1の画像 1
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 9、 1の画像 1
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 10、 1の画像 1
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 11、 1の画像 1
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 12、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Canon PowerShot S50 Front Panel/Battery Door Replacement: 手順 13、 1の画像 1
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
終わりに
作成者
5人の作成者と共同で作成されました。
Karim
メンバー登録日: 04/12/12
24 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 7-34, Maness Spring 2012 Cal Poly, Team 7-34, Maness Spring 2012人のメンバー
CPSU-MANESS-S12S7G34
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 1,273
