メインコンテンツにスキップ
はじめに
This guide demonstrates how to remove and replace the battery pack.
  1. Turn the camera with the bottom side facing up. Locate the panel labeled "Batt. Open"
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  3. Rotate the camera so that the slot is horizontal.
    • Rotate the camera so that the slot is horizontal.
    • Pull the orange lever and the battery will spring out slightly.
  4. Grasp battery and fully pull out of slot
    • Grasp battery and fully pull out of slot
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
まとめ
After a new battery has been inserted, close the swinging door and you're done.
Randy Lormand
メンバー登録日: 2011年01月23日
331 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G27
4 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,361
