メインコンテンツにスキップ
はじめに
This guide provides instructions on how to replace the shutter button assembly on the Canon PowerShot S400.
パーツ
パーツは指定されていません。
  1. Unless otherwise stated,a #00 philips screwdriver will be used to remove screws. Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Remove the two screws located on the right side of the camera.(the side with the USB adaption plug) Remove the four screws on the left side of the camera. This will release a small metal plate. Remove this plate.
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it. Now separate the front and back camera casings. Now separate the front and back camera casings.
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  5. Using a spudger, carefully pry the shutter button assembly from the camera.
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
まとめ
Ross Bryan
メンバー登録日: 2011年01月21日
350 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G19
4 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 2,491
