はじめに
This guide illustrates how to replace the motherboard in the S400.
  1. Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws. On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
  2. On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
  3. On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount. Remove the two small metal plates, which the four screws held in place. Remove the two small metal plates, which the four screws held in place.
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws held in place.
  4. When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case. Remove the small black plastic piece and set it aside.
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside.
    • If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
  5. Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
  6. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  7. A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera. Gently release the black latch. Remove the ribbon cable and metal plate assembly.
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
  8. On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen. Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
  9. Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
  10. Remove the LCD screen and set it aside. Remove the LCD screen and set it aside.
    • Remove the LCD screen and set it aside.
  11. On the main circuit board, gently release the black latches of the four ribbon cables.
    • On the main circuit board, gently release the black latches of the four ribbon cables.
    • Gently detach the ribbon cables.
  12. Detach the white-capped and green-capped wires, which sit near the flash. Detach the white-capped and green-capped wires, which sit near the flash.
    • Detach the white-capped and green-capped wires, which sit near the flash.
  13. Using a spudger, gently detach the shutter button assembly from the camera.
    • Using a spudger, gently detach the shutter button assembly from the camera.
  14. Remove the four 3.5 mm screws that hold the main circuit board.
    • Remove the four 3.5 mm screws that hold the main circuit board.
    • Do not remove the main circuit board yet.
  15. Do not completely remove the main circuit board from the camera. A soldered ribbon cable still attaches the board to the camera. Complete removal would break the soldering points. In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
    • Do not completely remove the main circuit board from the camera. A soldered ribbon cable still attaches the board to the camera. Complete removal would break the soldering points.
    • In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
    • Gently detach the white ribbon cable from the underside of the main circuit board.
  16. Do not attempt this next step unless you have soldering experience and feel comfortable desoldering. Otherwise you may damage the camera. Gently desolder the two ribbon cables attached to the motherboard.
    • Do not attempt this next step unless you have soldering experience and feel comfortable desoldering. Otherwise you may damage the camera.
    • Gently desolder the two ribbon cables attached to the motherboard.
    • Remove the motherboard.
まとめ
2 の人々がこのガイドを完成させました。
Ross Bryan
メンバー登録日: 2011年01月21日
350 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G19
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,725
