メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot S400 LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot S400 LCD Screen Replacement, LCD Screen: 手順 1、 2の画像 1 Canon PowerShot S400 LCD Screen Replacement, LCD Screen: 手順 1、 2の画像 2
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
    FixBotに聞いてみる
    コメントを追加
  2. Canon PowerShot S400 LCD Screen Replacement: 手順 2、 1の画像 1
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
    FixBotに聞いてみる
    コメントを追加
  3. Canon PowerShot S400 LCD Screen Replacement: 手順 3、 3の画像 1 Canon PowerShot S400 LCD Screen Replacement: 手順 3、 3の画像 2 Canon PowerShot S400 LCD Screen Replacement: 手順 3、 3の画像 3
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws hold in place.
    FixBotに聞いてみる
    コメントを追加
  4. Canon PowerShot S400 LCD Screen Replacement: 手順 4、 2の画像 1 Canon PowerShot S400 LCD Screen Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
    FixBotに聞いてみる
    コメントを追加
  5. Canon PowerShot S400 LCD Screen Replacement: 手順 5、 1の画像 1
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
    FixBotに聞いてみる
    コメントを追加
  6. Canon PowerShot S400 LCD Screen Replacement: 手順 6、 3の画像 1 Canon PowerShot S400 LCD Screen Replacement: 手順 6、 3の画像 2 Canon PowerShot S400 LCD Screen Replacement: 手順 6、 3の画像 3
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
    FixBotに聞いてみる
    コメントを追加
  7. Canon PowerShot S400 LCD Screen Replacement: 手順 7、 2の画像 1 Canon PowerShot S400 LCD Screen Replacement: 手順 7、 2の画像 2
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  8. Canon PowerShot S400 LCD Screen Replacement: 手順 8、 1の画像 1
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  9. Canon PowerShot S400 LCD Screen Replacement: 手順 9、 2の画像 1 Canon PowerShot S400 LCD Screen Replacement: 手順 9、 2の画像 2
    • Remove the LCD screen and set it aside.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
12人の作成者と共同で作成されました。
Ross Bryan
メンバー登録日: 01/21/11
375 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G19
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 54
今までの合計 3,772
