メインコンテンツにスキップ
Canon PowerShot S400 Battery Replacement
必要な工具と部品
  1. Canon PowerShot S400 Battery Replacement, LCD Screen: 手順 1、 2の画像 1 Canon PowerShot S400 Battery Replacement, LCD Screen: 手順 1、 2の画像 2
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
  2. Canon PowerShot S400 Battery Replacement: 手順 2、 1の画像 1
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
  3. Canon PowerShot S400 Battery Replacement: 手順 3、 3の画像 1 Canon PowerShot S400 Battery Replacement: 手順 3、 3の画像 2 Canon PowerShot S400 Battery Replacement: 手順 3、 3の画像 3
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws hold in place.
  4. Canon PowerShot S400 Battery Replacement: 手順 4、 2の画像 1 Canon PowerShot S400 Battery Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
  5. Canon PowerShot S400 Battery Replacement: 手順 5、 1の画像 1
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
  6. Canon PowerShot S400 Battery Replacement: 手順 6、 3の画像 1 Canon PowerShot S400 Battery Replacement: 手順 6、 3の画像 2 Canon PowerShot S400 Battery Replacement: 手順 6、 3の画像 3
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
  7. Canon PowerShot S400 Battery Replacement: 手順 7、 2の画像 1 Canon PowerShot S400 Battery Replacement: 手順 7、 2の画像 2
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
  8. Canon PowerShot S400 Battery Replacement: 手順 8、 1の画像 1
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
  9. Canon PowerShot S400 Battery Replacement: 手順 9、 2の画像 1 Canon PowerShot S400 Battery Replacement: 手順 9、 2の画像 2
    • Remove the LCD screen and set it aside.
  10. Canon PowerShot S400 Battery Replacement, Battery: 手順 10、 1の画像 1
    • Locate the ribbon cable connection to the left of the lens on the main circuit board.
    • Gently flip open the black latch on the connector and detach the ribbon cable.
  11. Canon PowerShot S400 Battery Replacement: 手順 11、 1の画像 1
    • Locate the three ribbon cables on the main circuit board. Gently flip open these black latches.
    • Gently disconnect the ribbon cables.
  12. Canon PowerShot S400 Battery Replacement: 手順 12、 2の画像 1 Canon PowerShot S400 Battery Replacement: 手順 12、 2の画像 2
    • Locate the white and green connectors underneath the flash.
    • Gently disconnect these connectors.
  13. Canon PowerShot S400 Battery Replacement: 手順 13、 1の画像 1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
  14. Canon PowerShot S400 Battery Replacement: 手順 14、 1の画像 1
    • Remove the four screws securing the main circuit board to the rest of the camera. (In the image, some of the screws have already been removed)
    • Do not remove the main circuit board yet.
  15. Canon PowerShot S400 Battery Replacement: 手順 15、 3の画像 1 Canon PowerShot S400 Battery Replacement: 手順 15、 3の画像 2 Canon PowerShot S400 Battery Replacement: 手順 15、 3の画像 3
    • Do not completely lift the circuit board off the camera. The circuit board is attached to the top of the camera by a soldered ribbon cable. Lifting the main circuit board off the camera will break these soldering points.
    • Gently lift the bottom of the main circuit board, the side without the soldered attachment points, like a hinge.
    • Locate the white ribbon cable attached to the underside of the main circuit board.
    • Gently remove the white ribbon cable from the connector.
  16. Canon PowerShot S400 Battery Replacement: 手順 16、 2の画像 1 Canon PowerShot S400 Battery Replacement: 手順 16、 2の画像 2
    • Locate and remove the three 3.45mm screws on the backside of the camera that secure the CF card slot.
    • Make note of the orientation of the ribbon cable connected to the CF card slot. You will need this for re-assembly.
    • Gently remove the CF card slot.
  17. Canon PowerShot S400 Battery Replacement: 手順 17、 1の画像 1
    • Orient the camera so you are looking at the top.
    • Locate the white connector that attaches the flex circuit to the capacitor.
    • You may have to pull the connector out of a small space behind the flash bulb in order to access it.
    • Disconnect the connector.
  18. Canon PowerShot S400 Battery Replacement: 手順 18、 1の画像 1
    • Adhesive tape attaches the flex circuit to the top of the camera. Gently un-stick the flex circuit from the tape, but do not completely remove the flex circuit.
  19. Canon PowerShot S400 Battery Replacement: 手順 19、 2の画像 1 Canon PowerShot S400 Battery Replacement: 手順 19、 2の画像 2
    • Remove the two 3.45mm screws located on the backside of the camera.
    • Separate the battery compartment and the lens-flash assembly.
  20. Canon PowerShot S400 Battery Replacement: 手順 20、 1の画像 1
    • Set the lens-flash assembly aside.
    • The next step requires the use of a soldering iron. Do not perform this step if you do not have experience soldering, you could permanently damage the mother board
    • De-solder the two soldered ribbon cables attached to the motherboard.
    • Separate the motherboard and battery case.
  21. Canon PowerShot S400 Battery Replacement: 手順 21、 1の画像 1
    • Replace battery casing
終わりに
作成者
6人の作成者と共同で作成されました。
Adam Grijalva
メンバー登録日: 01/20/11
202 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G19
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 38
今までの合計 3,219
