メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot S110 Display Replacement
必要な工具と部品
  1. Canon PowerShot S110 Display  Replacement, Display: 手順 1、 2の画像 1 Canon PowerShot S110 Display  Replacement, Display: 手順 1、 2の画像 2
    • Slide open the battery cover on the bottom of the camera.
    • Eject the battery by pulling the red release latch.
    • Battery must be removed to avoid shorting any part of the camera
  2. Canon PowerShot S110 Display  Replacement: 手順 2、 3の画像 1 Canon PowerShot S110 Display  Replacement: 手順 2、 3の画像 2 Canon PowerShot S110 Display  Replacement: 手順 2、 3の画像 3
    • Use a #0 Phillips screwdriver to remove the following screws:
    • the 2 screws on the side of the camera near the HDMI input panel,
    • the 2 screws on the opposite side of the camera,
    • and the 2 screws on the bottom of the camera near the tripod mounting hole.
  3. Canon PowerShot S110 Display  Replacement: 手順 3、 1の画像 1
    • Once the screws are removed, use a spudger to carefully detach the cover.
  4. Canon PowerShot S110 Display  Replacement: 手順 4、 2の画像 1 Canon PowerShot S110 Display  Replacement: 手順 4、 2の画像 2
    • Before we are able to remove the display, we must take off the mounting bracket that holds it in place.
    • Remove the single screw indicated in red.
    • Detach the bracket and set it aside.
    • In preparation for the next step, remove the screw indicated in yellow.
  5. Canon PowerShot S110 Display  Replacement: 手順 5、 3の画像 1 Canon PowerShot S110 Display  Replacement: 手順 5、 3の画像 2 Canon PowerShot S110 Display  Replacement: 手順 5、 3の画像 3
    • To detach the first logic ribbon:
    • Use a small, relatively soft pointed tool to slowly pull out the ribbon using the hole shown in the image.
    • Completely remove the ribbon.
    • The display is now partially disconnected from the back side of the camera.
  6. Canon PowerShot S110 Display  Replacement: 手順 6、 3の画像 1 Canon PowerShot S110 Display  Replacement: 手順 6、 3の画像 2 Canon PowerShot S110 Display  Replacement: 手順 6、 3の画像 3
    • To remove the front camera case in order to access the remaining ribbons:
    • Slowly pry around the edges using a spudger.
    • A circular ring pad will detach. Set this aside.
    • You now have access to the logic ribbons on the front of the camera.
  7. Canon PowerShot S110 Display  Replacement: 手順 7、 3の画像 1 Canon PowerShot S110 Display  Replacement: 手順 7、 3の画像 2 Canon PowerShot S110 Display  Replacement: 手順 7、 3の画像 3
    • Using the spudger, flip the small tab that is holding down the logic ribbon located at the top left corner.
    • Flip the larger tab that is holding down the logic ribbon located directly to the right of the previous ribbon.
    • Detach both ribbons from the circuit board.
  8. Canon PowerShot S110 Display  Replacement: 手順 8、 3の画像 1 Canon PowerShot S110 Display  Replacement: 手順 8、 3の画像 2 Canon PowerShot S110 Display  Replacement: 手順 8、 3の画像 3
    • Flip the tab and remove the last ribbon.
    • This ribbon is revealed after Step 7.
    • The display can now be lifted off the camera and the logic ribbons attached in the front can slide out.
    • Prepare your replacement display and move on to reassembly.
終わりに
Reassembly
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
akac92
メンバー登録日: 07/14/15
319 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team 1-2, Liner SU 2015 UW Tacoma, Team 1-2, Liner SU 2015人のメンバー
UWT-LINER-SU15S1G2
4 メンバー
5のガイドは作成済み
10件のガイドコメント
Oh My God, it works!!! Thanks for the great instructions, very clear and easy.
Thank you!!!
robertmadsen2000 - 返信
Caution, the re-assembly is much more challenging than the dear-down. Masking tape (to temporarily hold the screen and func. set dial assembly in place while attaching the ribbon cables), tooth picks (the ends fit nicely in the ribbon cable holes) and a small plastic putty knife (for raising cable hold-downs) nay come in handy. You will find that the camera face has a ribbon cable for the control ring. When reassembling, note that there are anchor nobs over which holes in the cables go - front side of camera. Reinserting the func set cable under the control ring after attaching the screen cables is difficult (tight fit). Try inserting tooth picks to make room. My new screen cost $30 from D H Cameras on eBay.
Dennis - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 22
過去 30 日: 45
今までの合計 4,134
