メインコンテンツにスキップ
Canon PowerShot S100 Top Panel Replacement
必要な工具と部品
  1. Canon PowerShot S100 Top Panel Replacement, Outer Case: 手順 1、 3の画像 1 Canon PowerShot S100 Top Panel Replacement, Outer Case: 手順 1、 3の画像 2 Canon PowerShot S100 Top Panel Replacement, Outer Case: 手順 1、 3の画像 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Top Panel Replacement: 手順 2、 1の画像 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Top Panel Replacement: 手順 3、 3の画像 1 Canon PowerShot S100 Top Panel Replacement: 手順 3、 3の画像 2 Canon PowerShot S100 Top Panel Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    購入する
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
  4. Canon PowerShot S100 Top Panel Replacement, Top Panel: 手順 4、 1の画像 1
    • Turn the camera over on its side so that the terminals are facing you.
    • Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
  5. Canon PowerShot S100 Top Panel Replacement: 手順 5、 2の画像 1 Canon PowerShot S100 Top Panel Replacement: 手順 5、 2の画像 2
    • Remove the screw (2.9mm, Phillips #00) that is directly above the camera lens.
  6. Canon PowerShot S100 Top Panel Replacement: 手順 6、 2の画像 1 Canon PowerShot S100 Top Panel Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using the spudger, remove the center ribbon cable that is connecting the top panel to the motherboard.
    • Gently lift the top panel off the camera.
    • Tweezers may also be used to remove the ribbon cable.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ricky
メンバー登録日: 02/23/15
958 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-4, Leahy Winter 2015 USF Tampa, Team 1-4, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 2,222
