メインコンテンツにスキップ
Canon PowerShot G9 SD-Card Slot Write Lock.
必要な工具と部品
  1. Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: 手順 1、 2の画像 1 Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: 手順 1、 2の画像 2
    • Be very careful not to touch any charged flash capacitor
    • Remove screws as marked. 2 for strap holder, 5 for back cover
    • Remove Back cover and strap holder
  2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: 手順 2、 2の画像 1 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: 手順 2、 2の画像 2
    • Remove the two screws circled green.
    • Remove the buttons.
  3. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 手順 3、 3の画像 1 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 手順 3、 3の画像 2 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 手順 3、 3の画像 3
    • Disconnect ribbon cable by lifting up flap.
    • Disconnect other cable (another flap)
    • Remove jog dial unit
  4. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: 手順 4、 2の画像 1 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: 手順 4、 2の画像 2
    • Remove the one screw circled green.
    • Remove the finder dial
  5. Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 手順 5、 3の画像 1 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 手順 5、 3の画像 2 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 手順 5、 3の画像 3
    • Remove screw and lift LCD upwards very carefully. Do not put any strain on cables.
    • Carefully remove flex cables. The left has a flap that needs to be opened (up), the right just needs to be pulled out. Be careful when re-inserting the right one, you can easily damage the fragile cable.
    • Remove the LCD
  6. Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 手順 6、 3の画像 1 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 手順 6、 3の画像 2 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 手順 6、 3の画像 3
    • Remove screws.
    • Disconnect connectors for Lens assembly
    • Carefully disconnect the tiny cable
    • Next step is removing the PCB. I made the mistake not to take care about the battery compartment switch. If you are not careful, the black lever will break off. Not a problem though, because then the camera will work also with opened battery compartmen
    • Remove main PCB by slightly bending outward the cover for the jack with fingernail. Now lift the PCB slightly upwards.
    • Look under the PCB, there is a connector that needs to be separated by means of a small screwdriver or spudger.
    • Re-attaching the connector is not easy. I used a small screwdriver to carefully press the connector back in place.
    • This is not the official method to do this. Normally the Top cover and several other parts need to be removed too.
  7. Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: 手順 7、 2の画像 1 Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: 手順 7、 2の画像 2
    • Measure continuity with a multimeter on SD-card slot write protect switch.
    • If it is not working, short the two points with a bodge wire, so write lock is disabled
    • Another possible fault is a broken soldering joint holding the case of the SD-card reader in place.
終わりに
Repeat the steps in order to reassemble your device.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Thomas Widmaier
メンバー登録日: 03/05/13
2,039 ポイント
10のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,521のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 1,040
