メインコンテンツにスキップ
Canon PowerShot G9 Disassembly Part I
必要な工具と部品
  1. Canon PowerShot G9 Disassembly Part I, Canon PowerShot G9 Disassembly Part I: 手順 1、 3の画像 1 Canon PowerShot G9 Disassembly Part I, Canon PowerShot G9 Disassembly Part I: 手順 1、 3の画像 2 Canon PowerShot G9 Disassembly Part I, Canon PowerShot G9 Disassembly Part I: 手順 1、 3の画像 3
    • The Canon PowerShot G9 made its debut around 2007. With 12.1 mega pixels and 3200 ISO, it's easily one of the more economical choice for amateur and hobbyists.
    • I mean, after 10 years it's still pretty good. The 12.1 mega pixel is more than needed, coupled with a 6x optical zoom to take sharp photos of everyday objects.
    • It got a few scuffs and maybe some dings and some paint scraped off (or it fell off on itself) but it's still very capable.
    • And yep, I did took out that 10 year old SD card. A miracle that it still works after a trip to the washing machine.
  2. Canon PowerShot G9 Disassembly Part I: 手順 2、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 2、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 2、 3の画像 3
    • For starters, we'll pop out that battery.
    • And the SD card, if you had not done that already.
    • The battery tolls in a good 720mAh @ 7.4 V with a capacity of 5.3Wh.
    • And ... there is a battery-eliminator for the G9 if you happen to take lots of photos indoors. Proof? A trap-door like mechanism on the side of the battery compartment -- for the wires to go in and out.
  3. Canon PowerShot G9 Disassembly Part I: 手順 3、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 3、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 3、 3の画像 3
    • We'll start attacking removing the screws on the outside of the machine.
    • Which tolls in at ... 6?
    • I'm not sure if there are screws around the mounting point (for the camera tri-pods). I don't have it on my unit ...
    • I know there will be a LOT of screws, so prepare some food container ... containers.
  4. Canon PowerShot G9 Disassembly Part I: 手順 4、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 4、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 4、 3の画像 3
    • The screws free up the rear ...
    • Case? Panel? Cover?
    • Which reveals a giant screen and ... some really delicate flex cables.
    • Let's start by removing the screen ....
    • Which have its flex cable trapped under the controls.
    • So let's start removing the buttons for now ...
  5. Canon PowerShot G9 Disassembly Part I: 手順 5、 1の画像 1
    • And ....
    • BOOBY TRAP!
    • Flick the board on its long sides out. Some of it may be snagged under the top ribbon cable, so do it carefully.
  6. Canon PowerShot G9 Disassembly Part I: 手順 6、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 6、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 6、 3の画像 3
    • So this part would be empty.
    • There will be a screw on the bottom holding down the display, so you will unscrew that ...
    • And then you would push the screen toward the bottom of the camera with your fingers.
    • And then the screen will ....
    • The flex cable had still a long way to go before being "free". Apparently we would need to remove the steel brackets ...
  7. Canon PowerShot G9 Disassembly Part I: 手順 7、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 7、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 7、 3の画像 3
    • Or you can try to lift the screen up ...?
    • Nothing's there. Brackets are the go-to.
    • You'll need to remove this screw ...
    • Which frees up this interesting button + roller combo.
  8. Canon PowerShot G9 Disassembly Part I: 手順 8、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 8、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 8、 3の画像 3
    • You will need to remove the screw below the buttons board too...
    • And THAT will give clear the entire screen (and buttons) assembly.
    • Flick the entire assembly upward and detach the other ribbon cable.
    • Display backlight? I can't figure out another use for that two-lane.
  9. Canon PowerShot G9 Disassembly Part I: 手順 9、 2の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 9、 2の画像 2
    • So this is how the camera looks like ...
    • You can see the lens assembly taking up a very large space.
    • That metal ... board in the center is probably where the CCD resides. Flashy ...
    • I'll DEFINITELY leave that for later. Look at that flex cable. It had a scary amount of connection AND test point.
    • So what are we here to do? We are supposed to remove everything, which includes the motherboard, and then I'll take apart the lens and clean its insides and outsides. Or I think I am going to do that.
  10. Canon PowerShot G9 Disassembly Part I: 手順 10、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 10、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 10、 3の画像 3
    • We had this ELPIDA DDR3 RAM HB0010A17EE for ... shots buffers?
    • Which is overlaid on ... a processor?
    • We had the Sony D4807GA823DG4V
    • 15019GB 7MR4G 07G
    • We had a unnamed IC and another ... IC on the front. But hey ... this one on the back is REALLY eye-catching. A exposed-die processor!
    • Could this be the GPU?
  11. Canon PowerShot G9 Disassembly Part I: 手順 11、 2の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 11、 2の画像 2
    • And to remove the motherboard, we will need to remove the top assembly (which appears to be a single large piece) which requires removal of the front ...
    • Cover? Panel? Plate?
    • Start by prying near the TOP of the front plate. There is a plastic tab holding it.
    • Hello .... how are you doing there?
  12. Canon PowerShot G9 Disassembly Part I: 手順 12、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 12、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 12、 3の画像 3
    • And then we'll go remove the upper assembly ...
    • You have this screw at the back ...
    • You had this screw on the front ... took me a while to figure it out.
    • And you had this screw on the right.
    • THAT one. The top one.
  13. Canon PowerShot G9 Disassembly Part I: 手順 13、 2の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 13、 2の画像 2
    • And ...
    • BOOBY TRAP!
    • Sadly, this is largely how it would be done. That tiny connector is for the microphone on top of the machine, near the function wheel.
    • Look at that assembly! It's absolutely monstrous -- the numerous dials, the power button, the playback button, the hot shoe ...
    • Some of which looks unnecessarily delicate, but hey, these are dials. Non-digital dials that use physical contact on every single click. And the copy-paste button (that's how I call it) had its own light.
    • Let's put it aside for now ...
  14. Canon PowerShot G9 Disassembly Part I: 手順 14、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 14、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 14、 3の画像 3
    • So, what do we have next?
    • Clearly you can't take out the power boards without the motherboard first.
    • So let's go do that. But heeeeyyyy....
    • What is Sony doing here?
    • Anyway. Let's remove this screw ....
    • And that screw(Far right).
  15. Canon PowerShot G9 Disassembly Part I: 手順 15、 2の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 15、 2の画像 2
    • And this screw on this weird ... "interconnect" board that houses a ...
    • RTC battery?
    • And flip the entire thing out ...
  16. Canon PowerShot G9 Disassembly Part I: 手順 16、 3の画像 1 Canon PowerShot G9 Disassembly Part I: 手順 16、 3の画像 2 Canon PowerShot G9 Disassembly Part I: 手順 16、 3の画像 3
    • So how exactly on earth should I do to remove these stuff without snagging a single copper line on these flex cables?
    • Answer: inter-board connectors.
    • BOOM! You're out.
    • Which leave us with this power board ...
    • Apparently the power is directed to the entire "system" part through this single connector, so the board is free to move after the screw is removed ...
    Canon G9 … brilliantly given instructions…thank you… however it looks overwhelming…are you in London? warmly mia
    Mia Manners - 返信
    No. I wrote this back in China. I am now in U.S.
    Xavier Jiang -
終わりに
To reassemble your device, follow these instructions in reverse order. CAREFULLY. After cleaning the dust. Or, continue to part II of the disassembly.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Xavier Jiang
メンバー登録日: 10/05/16
1,829 ポイント
7のガイドは作成済み
1 Guide Comment
Can someone do a more detailed guide or add more steps in this?
Sue - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 72
今までの合計 2,828
