メインコンテンツにスキップ
Canon PowerShot G16 Button Circuit Board Replacement
必要な工具と部品
  1. Canon PowerShot G16 Button Circuit Board Replacement, Battery: 手順 1、 3の画像 1 Canon PowerShot G16 Button Circuit Board Replacement, Battery: 手順 1、 3の画像 2 Canon PowerShot G16 Button Circuit Board Replacement, Battery: 手順 1、 3の画像 3
    • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
    • Remove your finger and allow the flap to pop open.
  2. Canon PowerShot G16 Button Circuit Board Replacement: 手順 2、 3の画像 1 Canon PowerShot G16 Button Circuit Board Replacement: 手順 2、 3の画像 2 Canon PowerShot G16 Button Circuit Board Replacement: 手順 2、 3の画像 3
    • Push the brown lever so that it pivots counterclockwise.
    • Grip and remove the battery.
  3. Canon PowerShot G16 Button Circuit Board Replacement, Button Circuit Board: 手順 3、 3の画像 1 Canon PowerShot G16 Button Circuit Board Replacement, Button Circuit Board: 手順 3、 3の画像 2 Canon PowerShot G16 Button Circuit Board Replacement, Button Circuit Board: 手順 3、 3の画像 3
    • Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
  4. Canon PowerShot G16 Button Circuit Board Replacement: 手順 4、 1の画像 1
    • Remove the four 3.3 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot G16 Button Circuit Board Replacement: 手順 5、 1の画像 1
    • Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
  6. Canon PowerShot G16 Button Circuit Board Replacement: 手順 6、 1の画像 1
    • Remove the two 3.3 mm screws near the speaker using a Phillips #00 screwdriver.
  7. Canon PowerShot G16 Button Circuit Board Replacement: 手順 7、 1の画像 1
    • Open the port cover by lifting up the tab with your finger and remove the 7.3 mm screw underneath the cover using a Phillips #00 screwdriver.
    • Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
  8. Canon PowerShot G16 Button Circuit Board Replacement: 手順 8、 2の画像 1 Canon PowerShot G16 Button Circuit Board Replacement: 手順 8、 2の画像 2
    • Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
  9. Canon PowerShot G16 Button Circuit Board Replacement: 手順 9、 1の画像 1
    • Using your fingers, carefully pry the front cover off starting at the bottom right.
  10. Canon PowerShot G16 Button Circuit Board Replacement: 手順 10、 2の画像 1 Canon PowerShot G16 Button Circuit Board Replacement: 手順 10、 2の画像 2
    • Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
    • Lift away the port cover housing.
  11. Canon PowerShot G16 Button Circuit Board Replacement: 手順 11、 1の画像 1
    この手順で使用する道具:
    • Reorient the camera so that you are looking at the back.
    • Make sure to pull the connector straight down as pulling up may cause harm to the connector.
    • Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
    • Pull the connector downwards with the tweezers.
  12. Canon PowerShot G16 Button Circuit Board Replacement: 手順 12、 1の画像 1
    • Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
    • Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
  13. Canon PowerShot G16 Button Circuit Board Replacement: 手順 13、 1の画像 1
    • Lift the button circuit board away from the camera.
終わりに
4 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Jonathan Harger
メンバー登録日: 01/11/16
1,258 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 70-6, Forte Winter 2016 Cal Poly, Team 70-6, Forte Winter 2016人のメンバー
CPSU-FORTE-W16S70G6
4 メンバー
7のガイドは作成済み
2 件のコメント
Your instructions were so simple. Now my Canon G15 is like new. Thanks so much for the good step by step instructions. Feel so fixing things on my own.
mhkoo1 - 返信
where do i buy a button circuit board
u81ou812 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 11
今までの合計 2,013
