メインコンテンツにスキップ
Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
必要な工具と部品
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: 手順 1、 2の画像 1 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: 手順 1、 2の画像 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 2、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 3、 1の画像 1
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 4、 1の画像 1
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 5、 1の画像 1
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 6、 2の画像 1 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 6、 2の画像 2
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 7、 1の画像 1
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 手順 8、 1の画像 1
    • Lift the panel off from the top of the camera with your hands.
終わりに
作成者
3人の作成者と共同で作成されました。
Michelle Ngo
メンバー登録日: 07/23/19
595 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019人のメンバー
UWT-LINER-SU19S1G3
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 316
