メインコンテンツにスキップ
Canon PowerShot ELPH 310 HS LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot ELPH 310 HS LCD Screen Replacement, External Panels: 手順 1、 1の画像 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 2、 2の画像 1 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 2、 2の画像 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 3、 2の画像 1 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 3、 2の画像 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 4、 2の画像 1 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 4、 2の画像 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 5、 1の画像 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 6、 2の画像 1 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 6、 2の画像 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 7、 1の画像 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: 手順 8、 2の画像 1 Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: 手順 8、 2の画像 2
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 9、 1の画像 1
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 10、 3の画像 1 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 10、 3の画像 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 手順 10、 3の画像 3
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
終わりに
作成者
2人の作成者と共同で作成されました。
Kadie Aldridge
メンバー登録日: 09/23/15
213 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team 1-4, Sydow campbell Fall 2015 University of Alabama, Team 1-4, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G4
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 17
今までの合計 977
