メインコンテンツにスキップ
Canon PowerShot ELPH 300HS Power Button Replacement
必要な工具と部品
    • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
    • Turn off your camera.
    • Remove the battery to prevent risk of shock.
  1. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Battery: 手順 2、 2の画像 1 Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Battery: 手順 2、 2の画像 2
    • Turn off your camera by pressing the power button, located on the top-center of the device.
    • Locate the battery door on the bottom right area of the camera case.
    • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
    • Locate the orange battery release button beneath the battery door.
    • Slide the battery release button downward to release the battery.
  2. Canon PowerShot ELPH 300HS Power Button Replacement, Left Side Screws: 手順 3、 1の画像 1
    • Be careful when removing screws, as they are stripped easily.
    • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
  3. Canon PowerShot ELPH 300HS Power Button Replacement, Bottom Screws: 手順 4、 1の画像 1
    • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
  4. Canon PowerShot ELPH 300HS Power Button Replacement, Right Side Screws: 手順 5、 1の画像 1
    • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
    • Remove the HDMI A/V out port cover located on the upper right side of the camera.
    • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
  5. Canon PowerShot ELPH 300HS Power Button Replacement: 手順 6、 1の画像 1
    • Remove the back portion of the camera case to reveal the screw located on the top of the case.
    • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
  6. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: 手順 7、 3の画像 1 Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: 手順 7、 3の画像 2 Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: 手順 7、 3の画像 3
    • Carefully pry the case apart at the seem, using your fingers.
    • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
    • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
  7. Canon PowerShot ELPH 300HS Power Button Replacement, Power Button: 手順 8、 2の画像 1 Canon PowerShot ELPH 300HS Power Button Replacement, Power Button: 手順 8、 2の画像 2
    • Disconnect the small cable from the yellow port on the motherboard
  8. Canon PowerShot ELPH 300HS Power Button Replacement: 手順 9、 1の画像 1
    • Disconnect the small cable from the blue port on the motherboard
  9. Canon PowerShot ELPH 300HS Power Button Replacement: 手順 10、 1の画像 1
    • Lift the plastic over the HDMI port on the side of the camera
  10. Canon PowerShot ELPH 300HS Power Button Replacement: 手順 11、 2の画像 1 Canon PowerShot ELPH 300HS Power Button Replacement: 手順 11、 2の画像 2
    • Lift from the back of the camera, angling forward and pull off to remove the power button assembly
終わりに
作成者
3人の作成者と共同で作成されました。
Kathryn Van Susante
メンバー登録日: 02/26/14
667 ポイント
5のガイドは作成済み
チーム
Michigan Tech, Team 5-6, Lauer Spring 2014 Michigan Tech, Team 5-6, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S5G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 2,258
