はじめに
The flash assembly is a retractable light bulb fixture that displays a quick burst of background light emited from a light bulb.
パーツ
パーツは指定されていません。
Now remove the top screw 3.3 mm long on the side of the camera that hold the side panels and the front cover using the #00 screwdriver.
Gently remove the side panel of the camera by pulling it away form the camera.
To reassemble your device, follow these instructions in reverse order. Remember to re-solder any wires that were unsoldered.
ある他の人がこのガイドを完成しました。
