メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot A80 Flash Assembly Replacement
必要な工具と部品
  1. Canon PowerShot A80 Flash Assembly Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove the three Phillips #00 screws from the bottom of the camera.
    FixBotに聞いてみる
    コメントを追加
  2. Canon PowerShot A80 Flash Assembly Replacement: 手順 2、 2の画像 1 Canon PowerShot A80 Flash Assembly Replacement: 手順 2、 2の画像 2
    • Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
    • Remove the memory card if it is still in the camera.
    • Use the Phillips #00 screwdriver to remove the single screw underneath the memory card slot door.
    FixBotに聞いてみる
    コメントを追加
  3. Canon PowerShot A80 Flash Assembly Replacement: 手順 3、 1の画像 1
    • Remove the Phillips #00 screw located inside the top of the memory card compartment.
    FixBotに聞いてみる
    コメントを追加
  4. Canon PowerShot A80 Flash Assembly Replacement: 手順 4、 2の画像 1 Canon PowerShot A80 Flash Assembly Replacement: 手順 4、 2の画像 2
    • Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
    • Remove the batteries from the compartment.
    • Remove the three Phillips #00 screws located inside the battery compartment.
    • The screw on the left is longer than the other two.
    FixBotに聞いてみる
    コメントを追加
  5. Canon PowerShot A80 Flash Assembly Replacement: 手順 5、 1の画像 1
    • Remove the top lid of the camera.
    • Be cautious of the fragile mylar cable that connects the lid to the main body of the camera.
    • Removing the lid takes a little force. Do this gently. There may be a snapping sound.
    • The door to the memory card compartment will be freed and should be removable now.
    • In other versions of this camera, there is a tab that secures the top from the wrist strap. If yours has this, you won't be able to completely separate the top until you have removed the top screw in Step 8.
    FixBotに聞いてみる
    コメントを追加
  6. Canon PowerShot A80 Flash Assembly Replacement: 手順 6、 1の画像 1
    • Remove the two Phillips #00 screws from the side of the camera.
    • Open the small rubber door below this screw that covers the connectors.
    FixBotに聞いてみる
    コメントを追加
  7. Canon PowerShot A80 Flash Assembly Replacement: 手順 7、 2の画像 1 Canon PowerShot A80 Flash Assembly Replacement: 手順 7、 2の画像 2
    • Open and pivot the LCD screen to its widest open position.
    • Remove the rear cover by pulling it straight away from the body of the camera.
    • When reassembling the camera, remember to replace the screws in the same location from which you removed them. Otherwise, you may damage the camera.
    FixBotに聞いてみる
    コメントを追加
  8. Canon PowerShot A80 Flash Assembly Replacement, Front Cover: 手順 8、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the 3.3 mm long top screw located on the side of the camera. This screw holds the side panels and the front cover together.
    • The side panel may get stuck on the internal wires, so gently wiggle this panel loose.
    FixBotに聞いてみる
    コメントを追加
  9. Canon PowerShot A80 Flash Assembly Replacement: 手順 9、 1の画像 1
    • Gently remove the side panel by pulling it away from the camera.
    FixBotに聞いてみる
    コメントを追加
  10. Canon PowerShot A80 Flash Assembly Replacement: 手順 10、 1の画像 1
    • Using the Phillips #00 screwdriver, unscrew the 2.4 mm long screw that holds on the front panel underneath the side panel.
    FixBotに聞いてみる
    コメントを追加
  11. Canon PowerShot A80 Flash Assembly Replacement: 手順 11、 1の画像 1
    • Underneath the battery cover there is a 3.8 mm screw in the corner. Using the Phillips #00 screwdriver, remove this screw.
    FixBotに聞いてみる
    コメントを追加
  12. Canon PowerShot A80 Flash Assembly Replacement: 手順 12、 1の画像 1
    • Gently pull up on the front cover to remove it from the body.
    FixBotに聞いてみる
    コメントを追加
  13. Canon PowerShot A80 Flash Assembly Replacement, Flash Assembly: 手順 13、 1の画像 1
    • Unscrew the 3.8 mm screw under the flash housing.
    FixBotに聞いてみる
    コメントを追加
  14. Canon PowerShot A80 Flash Assembly Replacement: 手順 14、 1の画像 1
    • Lift up black cover.
    • Black cover is attached to the top of the capacitor with adhesive.
    FixBotに聞いてみる
    コメントを追加
  15. Canon PowerShot A80 Flash Assembly Replacement: 手順 15、 1の画像 1
    • If the entire flash housing needs to be replaced...
    • Unsolder the black and red wires from the back of the circuit board behind the flash.
    FixBotに聞いてみる
    コメントを追加
  16. Canon PowerShot A80 Flash Assembly Replacement: 手順 16、 2の画像 1 Canon PowerShot A80 Flash Assembly Replacement: 手順 16、 2の画像 2
    • Use the opening tool to unclip both sides of the black cover on top of the flash
    FixBotに聞いてみる
    コメントを追加
  17. Canon PowerShot A80 Flash Assembly Replacement: 手順 17、 1の画像 1
    • Use the opening tool to lift off the black flash cover.
    FixBotに聞いてみる
    コメントを追加
  18. Canon PowerShot A80 Flash Assembly Replacement: 手順 18、 1の画像 1
    • If the flash needs to to fixed...
    • Unsolder the brown wire from the circuit board.
    • The piece of metal that attaches these parts will have to be bent back.
    • Make sure the capacitor is discharged before these steps are attempted. Do so with a screwdriver with a rubber handle.
    FixBotに聞いてみる
    コメントを追加
  19. Canon PowerShot A80 Flash Assembly Replacement: 手順 19、 1の画像 1
    • Unsolder the gray wire attached to the capacitor.
    • This is the last wire that connects to the flash.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Remember to re-solder any wires that were unsoldered.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
12人の作成者と共同で作成されました。
ryne contreras
メンバー登録日: 01/28/11
141 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S7G31
6 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 11
過去 30 日: 45
今までの合計 3,965
