メインコンテンツにスキップ
Canon PowerShot A75 Speaker Replacement
必要な工具と部品
  1. Canon PowerShot A75 Speaker Replacement, Batteries: 手順 1、 1の画像 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Speaker Replacement: 手順 2、 3の画像 1 Canon PowerShot A75 Speaker Replacement: 手順 2、 3の画像 2 Canon PowerShot A75 Speaker Replacement: 手順 2、 3の画像 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Speaker Replacement: 手順 3、 3の画像 1 Canon PowerShot A75 Speaker Replacement: 手順 3、 3の画像 2 Canon PowerShot A75 Speaker Replacement: 手順 3、 3の画像 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Speaker Replacement, Speaker: 手順 4、 2の画像 1 Canon PowerShot A75 Speaker Replacement, Speaker: 手順 4、 2の画像 2
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  5. Canon PowerShot A75 Speaker Replacement: 手順 5、 1の画像 1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  6. Canon PowerShot A75 Speaker Replacement: 手順 6、 2の画像 1 Canon PowerShot A75 Speaker Replacement: 手順 6、 2の画像 2
    • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  7. Canon PowerShot A75 Speaker Replacement: 手順 7、 3の画像 1 Canon PowerShot A75 Speaker Replacement: 手順 7、 3の画像 2 Canon PowerShot A75 Speaker Replacement: 手順 7、 3の画像 3
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  8. Canon PowerShot A75 Speaker Replacement: 手順 8、 1の画像 1
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
終わりに
作成者
5人の作成者と共同で作成されました。
Austin Fox
メンバー登録日: 04/11/12
1 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S17G30
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 383
