メインコンテンツにスキップ
Canon PowerShot A630 Trigger Button Replacement
必要な工具と部品
  1. Canon PowerShot A630 Trigger Button Replacement, Front Panel: 手順 1、 2の画像 1 Canon PowerShot A630 Trigger Button Replacement, Front Panel: 手順 1、 2の画像 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Trigger Button Replacement: 手順 2、 2の画像 1 Canon PowerShot A630 Trigger Button Replacement: 手順 2、 2の画像 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Trigger Button Replacement: 手順 3、 1の画像 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Trigger Button Replacement: 手順 4、 2の画像 1 Canon PowerShot A630 Trigger Button Replacement: 手順 4、 2の画像 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Trigger Button Replacement: 手順 5、 2の画像 1 Canon PowerShot A630 Trigger Button Replacement: 手順 5、 2の画像 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Trigger Button Replacement: 手順 6、 1の画像 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Trigger Button Replacement: 手順 7、 2の画像 1 Canon PowerShot A630 Trigger Button Replacement: 手順 7、 2の画像 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Trigger Button Replacement, Trigger Button: 手順 8、 1の画像 1
    • Use the spudger to gently pull back the retaining clip and pull the ribbon out
    • The top panel should now be completely detached from the camera
    • Applying to much force to the spudger may damage the retaining clip
  9. Canon PowerShot A630 Trigger Button Replacement: 手順 9、 1の画像 1
    • Remove the two screws holding down the metal frame using the Phillips #00 screwdriver
  10. Canon PowerShot A630 Trigger Button Replacement: 手順 10、 1の画像 1
    • Lift up the metal frame to expose the two screws located under the trigger button.
    • Remove the two screws using Phillips #00 screwdriver
  11. Canon PowerShot A630 Trigger Button Replacement: 手順 11、 2の画像 1 Canon PowerShot A630 Trigger Button Replacement: 手順 11、 2の画像 2
    • Trigger button should fall out
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kelly Duggan
メンバー登録日: 10/13/14
460 ポイント
3のガイドは作成済み
チーム
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S2G5
4 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 17
今までの合計 640
