メインコンテンツにスキップ
Canon PowerShot A630 Shooting Mode Dial Replacement
必要な工具と部品
  1. Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: 手順 1、 2の画像 1 Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: 手順 1、 2の画像 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 2、 2の画像 1 Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 2、 2の画像 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 3、 1の画像 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 4、 2の画像 1 Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 4、 2の画像 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 5、 2の画像 1 Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 5、 2の画像 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 6、 1の画像 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 7、 2の画像 1 Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 7、 2の画像 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: 手順 8、 2の画像 1 Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: 手順 8、 2の画像 2
    • Pry open the connector on the yellow ribbon cable using a plastic opening tool.
  9. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 9、 1の画像 1
    • Remove the 2 mm screws from the metal plate.
  10. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 10、 1の画像 1
    • Pull away the metal plate, exposing the underbelly of the mode dial.
    • Be careful not to pull too hard. Metal plate should remain attached.
  11. Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 11、 2の画像 1 Canon PowerShot A630 Shooting Mode Dial Replacement: 手順 11、 2の画像 2
    • Remove the 2mm screw using the #00 Phillips screwdriver.
    • The mode dial should fall out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Alicia Burns
メンバー登録日: 10/13/14
574 ポイント
5のガイドは作成済み
チーム
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S2G5
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 527
