メインコンテンツにスキップ
Canon PowerShot A620 Shutter Button Replacement
必要な工具と部品
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: 手順 1、 3の画像 1 Canon PowerShot A620 Shutter Button Replacement, Side Panel: 手順 1、 3の画像 2 Canon PowerShot A620 Shutter Button Replacement, Side Panel: 手順 1、 3の画像 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: 手順 2、 1の画像 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: 手順 3、 1の画像 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 手順 4、 2の画像 1 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 手順 4、 2の画像 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: 手順 5、 1の画像 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: 手順 6、 2の画像 1 Canon PowerShot A620 Shutter Button Replacement, Front Panel: 手順 6、 2の画像 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 手順 7、 2の画像 1 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 手順 7、 2の画像 2
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: 手順 8、 2の画像 1 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: 手順 8、 2の画像 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: 手順 9、 2の画像 1 Canon PowerShot A620 Shutter Button Replacement, Back Panel: 手順 9、 2の画像 2
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: 手順 10、 2の画像 1 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: 手順 10、 2の画像 2
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: 手順 11、 1の画像 1
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: 手順 12、 2の画像 1 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: 手順 12、 2の画像 2
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: 手順 13、 1の画像 1
    • The trigger button will fall off once the screws have been removed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jaime Abraham
メンバー登録日: 09/08/14
350 ポイント
3のガイドは作成済み
チーム
CSU Fullerton, Team 1-1, Bruce Fall 2014 CSU Fullerton, Team 1-1, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S1G1
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 42
今までの合計 1,468
