メインコンテンツにスキップ
Canon PowerShot A610 Broken Control Buttons Repair
必要な工具と部品
  1. Canon PowerShot A610 Broken Control Buttons Repair, Batteries: 手順 1、 2の画像 1 Canon PowerShot A610 Broken Control Buttons Repair, Batteries: 手順 1、 2の画像 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon PowerShot A610 Broken Control Buttons Repair: 手順 2、 1の画像 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: 手順 3、 3の画像 1 Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: 手順 3、 3の画像 2 Canon PowerShot A610 Broken Control Buttons Repair, Camera Housing: 手順 3、 3の画像 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon PowerShot A610 Broken Control Buttons Repair: 手順 4、 1の画像 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon PowerShot A610 Broken Control Buttons Repair: 手順 5、 1の画像 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon PowerShot A610 Broken Control Buttons Repair: 手順 6、 2の画像 1 Canon PowerShot A610 Broken Control Buttons Repair: 手順 6、 2の画像 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon PowerShot A610 Broken Control Buttons Repair: 手順 7、 1の画像 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon PowerShot A610 Broken Control Buttons Repair: 手順 8、 2の画像 1 Canon PowerShot A610 Broken Control Buttons Repair: 手順 8、 2の画像 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon PowerShot A610 Broken Control Buttons Repair: 手順 9、 2の画像 1 Canon PowerShot A610 Broken Control Buttons Repair: 手順 9、 2の画像 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon PowerShot A610 Broken Control Buttons Repair: 手順 10、 3の画像 1 Canon PowerShot A610 Broken Control Buttons Repair: 手順 10、 3の画像 2 Canon PowerShot A610 Broken Control Buttons Repair: 手順 10、 3の画像 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
  11. Canon PowerShot A610 Broken Control Buttons Repair, Canon PowerShot A610 Broken Control Buttons Repair: 手順 11、 2の画像 1 Canon PowerShot A610 Broken Control Buttons Repair, Canon PowerShot A610 Broken Control Buttons Repair: 手順 11、 2の画像 2
    • Remove the back casing.
    • Flip the casing over and push on the back of the broken button with either your finger or a blunt object until it realigns into its slot.
終わりに
作成者
4人の作成者と共同で作成されました。
Matthew Ramirez
メンバー登録日: 01/20/11
625 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 11-26, Maness Winter 2011 Cal Poly, Team 11-26, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G26
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 5,241
