メインコンテンツにスキップ
Canon PowerShot A590 IS LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot A590 IS LCD Screen Replacement, Batteries: 手順 1、 2の画像 1 Canon PowerShot A590 IS LCD Screen Replacement, Batteries: 手順 1、 2の画像 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS LCD Screen Replacement: 手順 2、 1の画像 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS LCD Screen Replacement: 手順 3、 1の画像 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS LCD Screen Replacement, Back Cover: 手順 4、 1の画像 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS LCD Screen Replacement: 手順 5、 1の画像 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS LCD Screen Replacement: 手順 6、 1の画像 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS LCD Screen Replacement: 手順 7、 1の画像 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
  8. Canon PowerShot A590 IS LCD Screen Replacement, LCD Screen: 手順 8、 1の画像 1
    • Remove the four screws near the corners of the LCD using a Phillips #00 screwdriver.
  9. Canon PowerShot A590 IS LCD Screen Replacement: 手順 9、 1の画像 1
    • CAUTION: The LCD is connected to the motherboard with different wires and a ribbon. Using too much force may disconnect these parts.
    • Gently lift the screen from the motherboard.
    • Keep the LCD pulled back in one hand.
  10. Canon PowerShot A590 IS LCD Screen Replacement: 手順 10、 1の画像 1
    • Use an iFixit opening tool to pull the black retaining clip up and disconnect the ribbon.
  11. Canon PowerShot A590 IS LCD Screen Replacement: 手順 11、 2の画像 1 Canon PowerShot A590 IS LCD Screen Replacement: 手順 11、 2の画像 2
    • Desolder the wires from the back of the LCD located in the bottom left corner.
    • Remove the solder from the wires.
    • Separate the LCD from the rest of the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
12人の作成者と共同で作成されました。
Zach
メンバー登録日: 10/11/10
281 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S9G19
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 32
今までの合計 9,690
