この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
First, we will locate the battery/memory card hatch. Second, we will change the main batteries and orient them properly. Third, we will change the clock battery.
必要な工具と部品
The battery hatch is on the bottom of the camera.
While the switch is pushed forward, pull the cover away from the camera.
This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
To install new batteries and reassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
