この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
必要な工具と部品
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
Using the iPod tool, push up gently around all edges of the camera.
7 の人々がこのガイドを完成させました。
コメント 1 件
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - 返信
