メインコンテンツにスキップ
Canon PowerShot A550 LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 手順 1、 3の画像 1 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 手順 1、 3の画像 2 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 手順 1、 3の画像 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Canon PowerShot A550 LCD Screen Replacement: 手順 2、 1の画像 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Canon PowerShot A550 LCD Screen Replacement: 手順 3、 1の画像 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Canon PowerShot A550 LCD Screen Replacement: 手順 4、 2の画像 1 Canon PowerShot A550 LCD Screen Replacement: 手順 4、 2の画像 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Canon PowerShot A550 LCD Screen Replacement: 手順 5、 1の画像 1
    • The camera should look like this once the front cover is removed.
  6. Canon PowerShot A550 LCD Screen Replacement: 手順 6、 3の画像 1 Canon PowerShot A550 LCD Screen Replacement: 手順 6、 3の画像 2 Canon PowerShot A550 LCD Screen Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Canon PowerShot A550 LCD Screen Replacement: 手順 7、 1の画像 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: 手順 8、 1の画像 1
    • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
  9. Canon PowerShot A550 LCD Screen Replacement: 手順 9、 2の画像 1 Canon PowerShot A550 LCD Screen Replacement: 手順 9、 2の画像 2
    • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
    • Slide the data cable out of the connector.
    • Caution: Do not force the data cable out of the connector. It may rip!
  10. Canon PowerShot A550 LCD Screen Replacement: 手順 10、 1の画像 1
    • The LCD screen can now be be removed to be fixed/replaced.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Precilla Tang
メンバー登録日: 04/19/11
162 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S8G6
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 3,616
