メインコンテンツにスキップ
Canon PowerShot A540 Function Key Motherboard Replacement
必要な工具と部品
  1. Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 2、 1の画像 1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 3、 1の画像 1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 4、 1の画像 1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 5、 3の画像 1 Canon PowerShot A540 Function Key Motherboard Replacement: 手順 5、 3の画像 2 Canon PowerShot A540 Function Key Motherboard Replacement: 手順 5、 3の画像 3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: 手順 6、 2の画像 1 Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: 手順 6、 2の画像 2
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 7、 2の画像 1 Canon PowerShot A540 Function Key Motherboard Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 8、 3の画像 1 Canon PowerShot A540 Function Key Motherboard Replacement: 手順 8、 3の画像 2 Canon PowerShot A540 Function Key Motherboard Replacement: 手順 8、 3の画像 3
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 9、 2の画像 1 Canon PowerShot A540 Function Key Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the two (2) 3.0 mm screws with the Phillips head #000 screwdriver.
  10. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 10、 2の画像 1 Canon PowerShot A540 Function Key Motherboard Replacement: 手順 10、 2の画像 2
    • Remove the orange ribbon from the clamp by using a Spudger to push the bar up.
  11. Canon PowerShot A540 Function Key Motherboard Replacement: 手順 11、 1の画像 1
    • Remove the Function Key Motherboard and replace.
    • There is another metal bar that comes off of the SD Card reader when screws are removed.
終わりに
作成者
3人の作成者と共同で作成されました。
Cooper Hale
メンバー登録日: 03/22/15
598 ポイント
3のガイドは作成済み
チーム
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G12
3 メンバー
20のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 834
