メインコンテンツにスキップ
Canon PowerShot A540 Front Cover Replacement
必要な工具と部品
  1. Canon PowerShot A540 Front Cover Replacement, Back Cover: 手順 1、 2の画像 1 Canon PowerShot A540 Front Cover Replacement, Back Cover: 手順 1、 2の画像 2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Front Cover Replacement: 手順 2、 1の画像 1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Front Cover Replacement: 手順 3、 1の画像 1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Front Cover Replacement: 手順 4、 1の画像 1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Front Cover Replacement: 手順 5、 3の画像 1 Canon PowerShot A540 Front Cover Replacement: 手順 5、 3の画像 2 Canon PowerShot A540 Front Cover Replacement: 手順 5、 3の画像 3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Front Cover Replacement, Front Cover: 手順 6、 2の画像 1 Canon PowerShot A540 Front Cover Replacement, Front Cover: 手順 6、 2の画像 2
    • Turn the camera to view the front.
    • Remove the lens guard.
    • Press the lens guard's button as you turn the guard counterclockwise.
  7. Canon PowerShot A540 Front Cover Replacement: 手順 7、 1の画像 1
    • Turn the camera to the side left of the LCD screen.
    • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
  8. Canon PowerShot A540 Front Cover Replacement: 手順 8、 1の画像 1
    • Remove the front cover gently.
    • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Carley Fuller
メンバー登録日: 03/23/15
434 ポイント
3のガイドは作成済み
チーム
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G12
3 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 1,517
