メインコンテンツにスキップ
Canon PowerShot A460 Motherboard Replacement
必要な工具と部品
  1. Canon PowerShot A460 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Motherboard Replacement: 手順 2、 1の画像 1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Motherboard Replacement: 手順 3、 1の画像 1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Motherboard Replacement, Front Casing: 手順 4、 1の画像 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Motherboard Replacement: 手順 5、 1の画像 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Motherboard Replacement: 手順 7、 1の画像 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Motherboard Replacement: 手順 8、 2の画像 1 Canon PowerShot A460 Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Motherboard Replacement: 手順 9、 3の画像 1 Canon PowerShot A460 Motherboard Replacement: 手順 9、 3の画像 2 Canon PowerShot A460 Motherboard Replacement: 手順 9、 3の画像 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Motherboard Replacement: 手順 10、 3の画像 1 Canon PowerShot A460 Motherboard Replacement: 手順 10、 3の画像 2 Canon PowerShot A460 Motherboard Replacement: 手順 10、 3の画像 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
  11. Canon PowerShot A460 Motherboard Replacement, Back Casing: 手順 11、 1の画像 1
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
  12. Canon PowerShot A460 Motherboard Replacement, LCD Screen: 手順 12、 1の画像 1
    • Remove the 4mm Phillips #00 screw from above the ribbon.
  13. Canon PowerShot A460 Motherboard Replacement: 手順 13、 1の画像 1
    • Gently peel off the blue tape on the top of the LCD screen.
  14. Canon PowerShot A460 Motherboard Replacement: 手順 14、 1の画像 1
    • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  15. Canon PowerShot A460 Motherboard Replacement: 手順 15、 1の画像 1
    • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  16. Canon PowerShot A460 Motherboard Replacement: 手順 16、 1の画像 1
    • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
  17. Canon PowerShot A460 Motherboard Replacement: 手順 17、 1の画像 1
    • Since the tabs have been lifted, the ribbon should now slide out out easily.
    • Be careful not to distort the ribbon in any way.
  18. Canon PowerShot A460 Motherboard Replacement, Motherboard: 手順 18、 1の画像 1
    • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
  19. Canon PowerShot A460 Motherboard Replacement: 手順 19、 2の画像 1 Canon PowerShot A460 Motherboard Replacement: 手順 19、 2の画像 2
    • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
    • Detach the black piece that the screws previously held in place.
  20. Canon PowerShot A460 Motherboard Replacement: 手順 20、 1の画像 1
    • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
  21. Canon PowerShot A460 Motherboard Replacement: 手順 21、 1の画像 1
    • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
  22. Canon PowerShot A460 Motherboard Replacement: 手順 22、 1の画像 1
    • Remove the 5mm Phillips #00 screw that is located on the top of camera.
  23. Canon PowerShot A460 Motherboard Replacement: 手順 23、 1の画像 1
    • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
    • Be careful not to damage the multiple adjacent orange ribbons.
  24. Canon PowerShot A460 Motherboard Replacement: 手順 24、 1の画像 1
    • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
  25. Canon PowerShot A460 Motherboard Replacement: 手順 25、 2の画像 1 Canon PowerShot A460 Motherboard Replacement: 手順 25、 2の画像 2
    • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
    • Once unlocked, slide out the ribbon.
  26. Canon PowerShot A460 Motherboard Replacement: 手順 26、 1の画像 1
    • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
  27. Canon PowerShot A460 Motherboard Replacement: 手順 27、 1の画像 1
    • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Tanner Coleman
メンバー登録日: 01/18/13
40 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G42
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 1,572
