はじめに
This guide will involve complete disassembly of the camera.
必要な工具と部品
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Since the tabs have been lifted, the ribbon should now slide out out easily.
Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
Remove the 4mm Phillips #00 screw that is located under the now disconnected top orange ribbon.
The lens piece can now be removed from the camera.
каким образом определить какой винт откуда? под каждой фотографией свои винты и они не соответствуют
3 の人々がこのガイドを完成させました。
コメント 1 件
please put a big warning note on the step after removing the blue tape from the lens. and the next on is where you lift something on the mother board with a spluger..something like that. well i used a screwdriver and got such a big electrical shock.... scared the crapola out of me. please make a note .... can get electrical shock....
