メインコンテンツにスキップ
Canon PowerShot A4000 IS Camera Lens Error Troubleshooting
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If there is a Visible Gap in the Lens: 手順 1、 1の画像 1
    • The first step for a lens error is to gently clean the leans with a clean cloth. If this does not work, then you proceed with the following steps.
    • Apply gentle pressure to the lens cover and move lens in a circular motion until you hear a "click".
  2. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Still Accessible: 手順 2、 1の画像 1
    • Hold down the menu button for at least 10 seconds and select the "Factory Reset" option to reset your lens.
  3. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Not Accessible: 手順 3、 1の画像 1
    • Remove the battery from your camera and replace it once it is fully charged or buy a new battery if your current one is over a year old. See Battery Removal for more details.
    • Once the battery is out, remove the memory card from camera as well. See Memory Card Replacement for more details.
    • Turning the camera on without a memory card will reset the camera. If the camera has been reset and displays a memory card error message, then the memory card can be reinserted and the camera turned on once again.
  4. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: 手順 4、 2の画像 1 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: 手順 4、 2の画像 2
    • Insert the A/V cable then plug the cable into a power supply or computer. Please see Connecting Camera to Computer for further instructions.
    • Turn the camera on by pushing the ON/OFF button.
  5. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: 手順 5、 2の画像 1 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: 手順 5、 2の画像 2
    • While turning the camera on by pushing the ON/OFF button, press and hold the MENU or FUNC. SET button.
ゴール
作成者
3人の作成者と共同で作成されました。
Ashley Heslip
メンバー登録日: 10/13/14
309 ポイント
3のガイドは作成済み
チーム
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S1G3
3 メンバー
17のガイドは作成済み
2 件のコメント
My lens is stuck out and won't go back in it says lens error and that it will shut off automatically what do I do?
trudiaguilar - 返信
I have done all of the above recommendations and my camera still has a lens error and lens won’t open… :-(
Rosie Bird - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 3,682
