メインコンテンツにスキップ
Canon PowerShot A3400 IS Flash Assembly Replacement
必要な工具と部品
  1. Canon PowerShot A3400 IS Flash Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 2、 1の画像 1
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: 手順 3、 2の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: 手順 3、 2の画像 2
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 4、 2の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 4、 2の画像 2
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 5、 1の画像 1
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 6、 1の画像 1
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 7、 1の画像 1
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 8、 2の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 8、 2の画像 2
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 9、 3の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 9、 3の画像 2 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 9、 3の画像 3
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 10、 3の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 10、 3の画像 2 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 10、 3の画像 3
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
  11. Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: 手順 11、 3の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: 手順 11、 3の画像 2 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: 手順 11、 3の画像 3
    • Remove the three 5 mm screws
  12. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 12、 3の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 12、 3の画像 2 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 12、 3の画像 3
    • Remove the screen by pulling at the two points as shown.
  13. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 13、 2の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 13、 2の画像 2
    • Remove the metal plate with the plastic opening tool.
  14. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 14、 2の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 14、 2の画像 2
    • Remove the 5 mm screw
  15. Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 15、 3の画像 1 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 15、 3の画像 2 Canon PowerShot A3400 IS Flash Assembly Replacement: 手順 15、 3の画像 3
    • Gently pull the flash assembly away.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Emily Pretorius
メンバー登録日: 01/13/15
325 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-1, Sullivan Winter 2015 USF Tampa, Team 1-1, Sullivan Winter 2015人のメンバー
USFT-SULLIVAN-W15S1G1
3 メンバー
8のガイドは作成済み
コメント 1 件
easy to take off but waste of putting it back together..
The Heat - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 8
今までの合計 475
