はじめに
The following steps will help you replace the flash assembly for the Canon PowerShot A3400 model. You would want to do this if the camera's flash is no longer functioning and you have exhausted your troubleshooting to the point where the source of the issue lies with the flash assembly.
必要な工具と部品
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
ある他の人がこのガイドを完成しました。
