メインコンテンツにスキップ
Canon PowerShot A2300 Back Cover Replacement
必要な工具と部品
  1. Canon PowerShot A2300 Back Cover Replacement, Front Cover: 手順 1、 1の画像 1
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Back Cover Replacement: 手順 2、 3の画像 1 Canon PowerShot A2300 Back Cover Replacement: 手順 2、 3の画像 2 Canon PowerShot A2300 Back Cover Replacement: 手順 2、 3の画像 3
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Back Cover Replacement: 手順 3、 2の画像 1 Canon PowerShot A2300 Back Cover Replacement: 手順 3、 2の画像 2
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Back Cover Replacement: 手順 4、 1の画像 1
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Back Cover Replacement: 手順 5、 1の画像 1
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
  6. Canon PowerShot A2300 Back Cover Replacement, Back Cover: 手順 6、 1の画像 1
    • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
    • Keep close to the table top in case the camera falls out of your hands.
  7. Canon PowerShot A2300 Back Cover Replacement: 手順 7、 1の画像 1
    • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
    • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
  8. Canon PowerShot A2300 Back Cover Replacement: 手順 8、 1の画像 1
    • Pry the top off by sliding the spudger under the On/Off button.
  9. Canon PowerShot A2300 Back Cover Replacement: 手順 9、 1の画像 1
    • Slide the cover to the right and off the camera.
    • Gently pry using the spudger on the right side if necessary.
    • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nathan McMillan
メンバー登録日: 03/23/15
366 ポイント
2のガイドは作成済み
チーム
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G14
4 メンバー
10のガイドは作成済み
2 件のコメント
How to share in photo camera to mobile
s0o149563 - 返信
How to share photos camera to mobile
s0o149563 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 520
