メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot A200 LCD Display Replacement
必要な工具と部品
    1. Canon PowerShot A200 LCD Display Replacement, Canon PowerShot A200: 手順 1、 1の画像 1
      • Use a Phillips #00 screwdriver to remove the two screws located at the bottom of the camera.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot A200 LCD Display Replacement: 手順 2、 2の画像 1 Canon PowerShot A200 LCD Display Replacement: 手順 2、 2の画像 2
      • Locate the screw and the rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
      • Remove the two screws with the Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot A200 LCD Display Replacement: 手順 3、 2の画像 1 Canon PowerShot A200 LCD Display Replacement: 手順 3、 2の画像 2
      • Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
      • Be sure to remove the memory card.
      • Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    4. Canon PowerShot A200 LCD Display Replacement: 手順 4、 2の画像 1 Canon PowerShot A200 LCD Display Replacement: 手順 4、 2の画像 2
      • Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
      • Remove the two visible screws with the Phillips #00 screwdriver.
      • During reassembly, the holes for these screws must align properly with the interior of the camera body. Then the black battery cover must lie flat and be held in place by the grey tab.
      FixBotに聞いてみる
      コメントを追加
    5. Canon PowerShot A200 LCD Display Replacement: 手順 5、 2の画像 1 Canon PowerShot A200 LCD Display Replacement: 手順 5、 2の画像 2
      • Remove the screen battery located to the left of the screen.
      • Set the screen battery aside for reassembly
      FixBotに聞いてみる
      コメントを追加
    6. Canon PowerShot A200 LCD Display Replacement: 手順 6、 2の画像 1 Canon PowerShot A200 LCD Display Replacement: 手順 6、 2の画像 2
      • Gently pull the camera apart from the top.
      • Be careful. The two halves are still attached by two short ribbons at the bottom of the camera.
      FixBotに聞いてみる
      コメントを追加
    7. Canon PowerShot A200 LCD Display Replacement: 手順 7、 2の画像 1 Canon PowerShot A200 LCD Display Replacement: 手順 7、 2の画像 2
      この手順で使用する道具:
      • Locate the black tabs on either side of the white ribbon.
      • Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
      • Gently pull the white ribbon out from its connection.
      FixBotに聞いてみる
      コメントを追加
    8. Canon PowerShot A200 LCD Display Replacement: 手順 8、 3の画像 1 Canon PowerShot A200 LCD Display Replacement: 手順 8、 3の画像 2 Canon PowerShot A200 LCD Display Replacement: 手順 8、 3の画像 3
      • Locate the black tabs on either side of the orange ribbon.
      • Gently pull the orange ribbon out of its connection.
      • Your camera will now be in two separate pieces.
      FixBotに聞いてみる
      コメントを追加
    1. Canon PowerShot A200 LCD Display Replacement, LCD Display: 手順 9、 1の画像 1
      • Use a Phillips head screwdriver to remove the four screws from the corners of the LCD.
      FixBotに聞いてみる
      コメントを追加
    2. Canon PowerShot A200 LCD Display Replacement: 手順 10、 1の画像 1
      • Use the iFixit plastic opening tool to lift the LCD away from the back case.
      • The LCD will still be attached to the back of the camera case by an orange strip.
      FixBotに聞いてみる
      コメントを追加
    3. Canon PowerShot A200 LCD Display Replacement: 手順 11、 1の画像 1
      • Use a soldering iron to remove the LCD from the orange cable connected to the back of the camera.
      • Use the soldering iron to attach your new LCD in place.
      • Caution: When soldering, allow enough slack in the orange cable, so the LCD will lie flat. The white bar will lie parallel with the electronic components embedded in the motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
Follow the instructions in the prerequisite guide Disassembling the Canon PowerShot A200 Case.
Once completed, proceed with installing a new LCD Display.
キャンセル: このガイドを終了できませんでした。
作成者
12人の作成者と共同で作成されました。
Jeff Barich
メンバー登録日: 01/28/11
101 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 7-37, Regan Winter 2011 Cal Poly, Team 7-37, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S7G37
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 26
今までの合計 1,405
