Locate the tabs on the top of the panel that hook down and into the black side panel.
Insert the Spudger in-between the black panel and the blue panel as shown and pull the two pieces apart.
You will hear some snapping. Don't panic: this is just the hooks un-clipping.
There is a tab you will have to push down to remove the part.
Once the tab is released, gently lift the cover away from the rest of the device to disengage the clips.
You will hear some snapping. Don't panic: this is just the clips un-clipping.
Remove the two screws from the USB reader using the Phillips #00 screwdriver.
The angle for removing the screws can be somewhat challenging, try not to get too frustrated.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
