この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This replacement is moderate in difficulty because it can be a bit tricky to get inside the side panels of the printer.
必要な工具と部品
There are a few tabs on the top of the panel that hook down and into the black side panel. Insert the tool in-between the black panel and the blue panel as shown and pull the two pieces apart.
There is a tab you will have to push down to remove the part.
Once the tab is released the cover must be gently lifted away from the rest of the device to disengage the clips.
After unclipping all the hooks, pull off the black side panel to reveal the inner circuit boards.
There is a large white wire that leads to the USB chip. As you are pulling out the chip, detach the wire.
4 の人々がこのガイドを完成させました。
