メインコンテンツにスキップ
Canon PIXMA MP620B USB Reader Replacement
必要な工具と部品
  1. Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: 手順 1、 2の画像 1 Canon PIXMA MP620B USB Reader Replacement, Pop off right blue side panel: 手順 1、 2の画像 2
    • Locate the tabs on the top of the panel that hook down and into the black side panel.
    • Insert the Spudger in-between the black panel and the blue panel as shown and pull the two pieces apart.
    • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
  2. Canon PIXMA MP620B USB Reader Replacement, Loosen the back panel: 手順 2、 1の画像 1
    • Remove the two screws from the back right black panel using the Phillips #00 screwdriver.
  3. Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: 手順 3、 2の画像 1 Canon PIXMA MP620B USB Reader Replacement, Pull off black side panel: 手順 3、 2の画像 2
    • There is a tab you will have to push down to remove the part.
    • Once the tab is released, gently lift the cover away from the rest of the device to disengage the clips.
    • You will hear some snapping. Don't panic: this is just the clips un-clipping.
  4. Canon PIXMA MP620B USB Reader Replacement, Take off the black side panel: 手順 4、 1の画像 1
    • After unclipping all the hooks, pull off the black side panel to reveal the inner circuit boards.
  5. Canon PIXMA MP620B USB Reader Replacement, Unscrew 2 screws from USB chip: 手順 5、 1の画像 1
    • Remove the two screws from the USB reader using the Phillips #00 screwdriver.
    • The angle for removing the screws can be somewhat challenging, try not to get too frustrated.
  6. Canon PIXMA MP620B USB Reader Replacement, Pull out USB chip and disconnect white wire: 手順 6、 1の画像 1
    • Disconnect the large white ribbon cable that leads to the USB reader. As you are pulling out the USB reader, carefully detach the ribbon.
終わりに
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Val Fedorikhin
メンバー登録日: 10/12/14
860 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G21
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 895
