メインコンテンツにスキップ
Canon PIXMA MP620B Ink Head Replacement
必要な工具と部品
  1. Canon PIXMA MP620B Ink Head Replacement, Ink Head: 手順 1、 2の画像 1 Canon PIXMA MP620B Ink Head Replacement, Ink Head: 手順 1、 2の画像 2
    • There are a few tabs on the top of the panel that hook down and into the black side panel. Insert the tool in-between the black panel and the blue panel as shown and pull the two pieces apart.
    • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
  2. Canon PIXMA MP620B Ink Head Replacement: 手順 2、 2の画像 1 Canon PIXMA MP620B Ink Head Replacement: 手順 2、 2の画像 2
    • Repeat the same process on the left side panel.
  3. Canon PIXMA MP620B Ink Head Replacement: 手順 3、 1の画像 1
    • Unhook the lid support by sliding the hook down and to the left. Make sure the support is fully disconnected before proceeding.
  4. Canon PIXMA MP620B Ink Head Replacement: 手順 4、 2の画像 1 Canon PIXMA MP620B Ink Head Replacement: 手順 4、 2の画像 2
    • Remove the four black screws on the back panels from both the left and right side.
  5. Canon PIXMA MP620B Ink Head Replacement: 手順 5、 3の画像 1 Canon PIXMA MP620B Ink Head Replacement: 手順 5、 3の画像 2 Canon PIXMA MP620B Ink Head Replacement: 手順 5、 3の画像 3
    • Remove the scanner by pulling the side panels out until the scanner pin is free. Set the scanner aside.
    • The scanner will still be attached with wires on the right side. Be careful not to yank the part away from the main body of the printer.
  6. Canon PIXMA MP620B Ink Head Replacement: 手順 6、 2の画像 1 Canon PIXMA MP620B Ink Head Replacement: 手順 6、 2の画像 2
    • Press down on the clip on the left side of the printer until it clicks, and pull the panel free.
  7. Canon PIXMA MP620B Ink Head Replacement: 手順 7、 2の画像 1 Canon PIXMA MP620B Ink Head Replacement: 手順 7、 2の画像 2
    • Press down on the clip on the right side panel until it clicks and then pull the panel free.
  8. Canon PIXMA MP620B Ink Head Replacement: 手順 8、 1の画像 1
    • Remove the plastic cover by depressing the clip located on the right side of the printer. Press the clip inwards until it clicks, and then lift the cover upwards and off the printer.
  9. Canon PIXMA MP620B Ink Head Replacement, Remove the three screws holding the top rear slider rail: 手順 9、 2の画像 1 Canon PIXMA MP620B Ink Head Replacement, Remove the three screws holding the top rear slider rail: 手順 9、 2の画像 2
    • Unscrew the three screws holding the rail.
  10. Canon PIXMA MP620B Ink Head Replacement, Remove the guiding cord: 手順 10、 1の画像 1
    • Remove the cord by pulling upwards on it and unhooking it from the pulleys on either end.
  11. Canon PIXMA MP620B Ink Head Replacement, Remove the ink head: 手順 11、 1の画像 1
    • Remove the ink head by pulling it away from the rail.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Val Fedorikhin
メンバー登録日: 10/12/14
860 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G21
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 34
今までの合計 3,299
