はじめに
Use this guide to replace or repair your speaker.
パーツ
パーツは必要ありません。
  1. Orient the camera so that the viewfinder is on your left and the lens is on your right.
    • Orient the camera so that the viewfinder is on your left and the lens is on your right.
    • Remove the 4mm #00 Phillips screw.
  2. Reorient the camera with the back button pad and viewfinder towards you.
    • Reorient the camera with the back button pad and viewfinder towards you.
    • Remove the three 4mm #00 Phillips screws shown on the rear face of camcorder.
  3. Remove the plastic cover from the rear of the camcorder by gently pulling it towards you while holding the camera as shown. The Battery Should be removed at this point, please ignore it in the picture.
    • Remove the plastic cover from the rear of the camcorder by gently pulling it towards you while holding the camera as shown.
    • The Battery Should be removed at this point, please ignore it in the picture.
  4. Remove the 4mm #00 Phillips screw located to the right of the LCD release switch.
    • Remove the 4mm #00 Phillips screw located to the right of the LCD release switch.
  5. Open the LCD by using the release switch.
    • Open the LCD by using the release switch.
    • Reorient the camera with the playback button pad and edge of LCD screen facing you.
    • Remove the 4mm #00 Phillips screw shown.
  6. Reorient the camera with the top facing you.  The side with the LCD screen should be on the right and the other side panel should be on the right.
    • Reorient the camera with the top facing you. The side with the LCD screen should be on the right and the other side panel should be on the right.
    • Open the pop up flash on the top of the camcorder.
    • A loud clicking noise is expected.
  7. Reorient the camera with the bottom facing you, LCD screen on the right, side panel on the left. Open the tape deck by sliding the switch and moving the deck cover to the left as shown.
    • Reorient the camera with the bottom facing you, LCD screen on the right, side panel on the left.
    • Open the tape deck by sliding the switch and moving the deck cover to the left as shown.
  8. Remove 4mm #00 Phillips screw.
    • Remove 4mm #00 Phillips screw.
  9. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  10. Reorient camera with lens facing  you.
    • Reorient camera with lens facing you.
    • Remove the #00 Philips 4mm screw shown on the hinge of the tape deck cover.
  11. To remove the camcorder lens hood, twist the hood to counterclockwise and it will come loose, then pull towards you. To remove the camcorder lens hood, twist the hood to counterclockwise and it will come loose, then pull towards you.
    • To remove the camcorder lens hood, twist the hood to counterclockwise and it will come loose, then pull towards you.
  12. Close the tape deck by gently pushing it toward the body of the camera. Slide and remove the plastic cover on the bottom right, exposing the interface shown.
    • Close the tape deck by gently pushing it toward the body of the camera.
    • Slide and remove the plastic cover on the bottom right, exposing the interface shown.
  13. Gently pull the front plastic cover towards you to remove. Gently pull the front plastic cover towards you to remove.
    • Gently pull the front plastic cover towards you to remove.
  14. Remove 2 Philips #00 4mm screw shown.
    • Remove 2 Philips #00 4mm screw shown.
  15. Reorient the camera so you are looking at the side of the camera with the viewfinder on the left and lens on the right.
    • Reorient the camera so you are looking at the side of the camera with the viewfinder on the left and lens on the right.
    • Holding the camera as shown,remove the 4mm #00 Phillips screw.
  16. Remove the 4 Philips #00 4mm screws shown.
    • Remove the 4 Philips #00 4mm screws shown.
  17. Reorient the camera with the lens facing you.
    • Reorient the camera with the lens facing you.
    • Gently pull the side panel of the camera to the right to remove.
    • Be aware that that there are wires connecting the cover to the body of the device, so the side cover will not come off entirely.
  18. The side of the device should now be open as shown.  Again, there are wire connections between the side cover and the body of the camcorder. Do not separate the two entirely!
    • The side of the device should now be open as shown. Again, there are wire connections between the side cover and the body of the camcorder. Do not separate the two entirely!
  19. Remove the screw above the speaker's housing.
    • Remove the screw above the speaker's housing.
  20. Remove the small battery with the "Caution" on it.
    • Remove the small battery with the "Caution" on it.
  21. Remove the screw from inside the battery housing.
    • Remove the screw from inside the battery housing.
  22. Remove the 3 screws holding the metal piece over the speaker.
    • Remove the 3 screws holding the metal piece over the speaker.
  23. Lift up and remove the metal cover.
    • Lift up and remove the metal cover.
  24. Lift and remove the speaker.
    • Lift and remove the speaker.
  25. Replace the broken speaker with a new one.
    • Replace the broken speaker with a new one.
    • The speaker's wires need to be desoldered.
まとめ
Jeanette Neethling
メンバー登録日: 2011年01月19日
531 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 1-12, Amido Winter 2011 Cal Poly, Team 1-12, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S1G12
4 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 599
