この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace the button pad.
必要な工具と部品
Orient the camera so that the back button panel and viewfinder are facing you.
Push the "Battery Release" button to the side and hold.
Orient the camera with the hand strap facing you.
Remove the two 4mm #00 Philips screws.
Orient the camera so that the viewfinder is on your left and the lens is on your right.
Remove the 4mm #00 Phillips screw.
Remove the #00 Philips 3mm screw as shown holding the small circuit board on the side panel.
