メインコンテンツにスキップ
Canon ImageCLASS MF4350d Scanner Belt Replacement
必要な工具と部品
  1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Disassembly: 手順 1、 1の画像 1
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 2、 3の画像 1 Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 2、 3の画像 2 Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 2、 3の画像 3
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 3、 3の画像 1 Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 3、 3の画像 2 Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 3、 3の画像 3
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 4、 1の画像 1
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 5、 2の画像 1 Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 5、 2の画像 2
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
  6. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: 手順 6、 2の画像 1 Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: 手順 6、 2の画像 2
    • Remove the black component by gently pulling it up from the black scanner belt
  7. Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 7、 2の画像 1 Canon ImageCLASS MF4350d Scanner Belt Replacement: 手順 7、 2の画像 2
    • Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
    • Take a new belt and put it in the same way that you took it out.
終わりに
作成者
5人の作成者と共同で作成されました。
Tanner Papenfuss
メンバー登録日: 09/30/13
560 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G1
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 19
今までの合計 2,870
