メインコンテンツにスキップ
Canon EOS Rebel XTi Snapshot Button Replacement
必要な工具と部品
  1. Canon EOS Rebel XTi Snapshot Button Replacement, Battery: 手順 1、 1の画像 1
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 2、 1の画像 1
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 3、 1の画像 1
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Canon EOS Rebel XTi Snapshot Button Replacement, Memory Card: 手順 4、 1の画像 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 5、 1の画像 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 6、 1の画像 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: 手順 7、 3の画像 1 Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: 手順 7、 3の画像 2 Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: 手順 7、 3の画像 3
    • Remove the single 10 mm JIS #00 shoulder screw.
    • Remove the two 6 mm JIS #00 screws.
  8. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 8、 1の画像 1
    • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
    • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
  9. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 9、 1の画像 1
    • Unplug the yellow connector located on the top of the camera.
  10. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 10、 1の画像 1
    • Disconnect the red connector located by the USB port.
  11. Canon EOS Rebel XTi Snapshot Button Replacement, Snapshot Button: 手順 11、 1の画像 1
    • Use a J00 screwdriver to remove the two silver 4 mm screws from underneath the snapshot button.
  12. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 12、 3の画像 1 Canon EOS Rebel XTi Snapshot Button Replacement: 手順 12、 3の画像 2 Canon EOS Rebel XTi Snapshot Button Replacement: 手順 12、 3の画像 3
    • Use a J00 screwdriver to remove the 3 mm screws from the plate under snapshot the snapshot button.
    • Place the components off to the side without removing any ribbons.
    • Be careful as ribbon cables are fragile and may rip easily.
  13. Canon EOS Rebel XTi Snapshot Button Replacement: 手順 13、 1の画像 1
    • Use a 1.5 flat head bit to remove the c-clip from underneath the snapshot button by pushing against the open side of the pin.
終わりに
作成者
3人の作成者と共同で作成されました。
Luis Calle
メンバー登録日: 08/30/15
416 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 8-6, Eyestone Fall 2015 USF Tampa, Team 8-6, Eyestone Fall 2015人のメンバー
USFT-EYESTONE-F15S8G6
3 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,026
