メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Use this guide to replace the interior eyepiece of the camera.
パーツ
パーツは指定されていません。
  1. Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Remove three medium length screws from the bottom of the camera
    • Remove three medium length screws from the bottom of the camera
  4. Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  6. Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  7. Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
  8. Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Be gentle when puling wires lose, use the tweezers to remove the wires.
  9. You can use your fingers to pull the top panel of the camera.
    • You can use your fingers to pull the top panel of the camera.
  10. After removing the top panel, you can use your fingers to remove the eye piece from the camera.
    • After removing the top panel, you can use your fingers to remove the eye piece from the camera.
終わりに
ある他の人がこのガイドを完成しました。
Daniel Bussone
メンバー登録日: 2011年01月28日
1,239 ポイント
11のガイドは作成済み
チーム
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G41
2 メンバー
21のガイドは作成済み
2 件のコメント
Is there a part number to order the interior eyepiece? It does me no good to take it apart if I don't have or can't find a replacement for it.
Erik - 返信
How do you replace the internal battery?
rideswchrist - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 26
今までの合計 6,741
