空欄の手順
申し訳ありませんが、この修理ガイドは、重要な手順が入っていません。
はじめに
手順 1 に進む ↓This is a necessary procedure for replacing the back latch of the Canon EOS Rebel XS 35mm camera. This guide details how to remove the back latch and put a back latch back on, whether it's the same back latch or a new one. The back latch covers and protects the film, among other things.
必要な工具と部品
ツール
Use a Phillips #000 screwdriver to remove the 7 mm screw.
Use a Phillips #000 screwdriver to remove the five 4 mm screws.
Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
Once the front, top, and bottom covers have all been removed, it's time to remove the back latch! Using a paperclip or something similar (anything that's very skinny), push on the end of the skinny, silver, metal rod that vertically travels through the camera. Do this until enough of the rod pops out on the other side for the next step.
1件のガイドコメント
This would be fantastic if only you'd noted a place to obtain a replacement latch from.
