メインコンテンツにスキップ
Canon EOS Rebel T5 SD Card Reader Replacement
必要な工具と部品
  1. Canon EOS Rebel T5 SD Card Reader Replacement, Battery: 手順 1、 1の画像 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 2、 1の画像 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 SD Card Reader Replacement, SD Card: 手順 3、 1の画像 1
  4. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 4、 1の画像 1
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
  5. Canon EOS Rebel T5 SD Card Reader Replacement, Back Panel: 手順 5、 1の画像 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  6. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 6、 1の画像 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  7. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 7、 1の画像 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  8. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 8、 1の画像 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  9. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 9、 3の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 9、 3の画像 2 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 9、 3の画像 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  10. Canon EOS Rebel T5 SD Card Reader Replacement, LCD Screen: 手順 10、 2の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement, LCD Screen: 手順 10、 2の画像 2
    • Remove the four silver 4mm Phillips #000 screws connecting the LCD screen to the back of the camera.
    • Be sure to lift the ribbon cable to remove the remaining hidden black 4mm Phillips #000 screw.
  11. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 11、 1の画像 1
    • The LCD screen can now be lifted from the right side to be replaced.
  12. Canon EOS Rebel T5 SD Card Reader Replacement, Motherboard: 手順 12、 1の画像 1
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
  13. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 13、 1の画像 1
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm Phillips #000 screws.
  14. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 14、 3の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 14、 3の画像 2 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 14、 3の画像 3
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  15. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 15、 1の画像 1
    • Remove the black 5 mm Phillips #000 screw, located under the grip.
  16. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 16、 1の画像 1
    • Remove the top panel of the device.
  17. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 17、 2の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 17、 2の画像 2
    • Remove the front panel of the camera.
  18. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 18、 3の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 18、 3の画像 2 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 18、 3の画像 3
    • Remove the five silver 5mm Phillips #000 screws.
    • The motherboard can now be removed.
  19. Canon EOS Rebel T5 SD Card Reader Replacement, Image Sensor: 手順 19、 2の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement, Image Sensor: 手順 19、 2の画像 2
    • Remove the three silver 3mm Philips #000 screws from the image sensor holder.
    • Remove the image sensor holder.
  20. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 20、 3の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 20、 3の画像 2 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 20、 3の画像 3
    • Remove the three remaining silver 3mm Philips #000 screws from the image sensor.
    • Be careful not lose the springs underneath the screws on the image sensor
    • Using your fingers, lift the image sensor from the device.
  21. Canon EOS Rebel T5 SD Card Reader Replacement, SD Card Reader: 手順 21、 1の画像 1
    • Using the plastic spuger, disconnect the wire strips that are attached to the SD card reader.
  22. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 22、 1の画像 1
    • Remove the three 3nm Phillips #000 screws connecting the SD card reader to the back of the device.
  23. Canon EOS Rebel T5 SD Card Reader Replacement: 手順 23、 2の画像 1 Canon EOS Rebel T5 SD Card Reader Replacement: 手順 23、 2の画像 2
    • Using your fingers, remove the SD card reader from the back of the device.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tyler Brown
メンバー登録日: 09/22/14
879 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015人のメンバー
USFT-WOLLERT-F15S16G4
4 メンバー
16のガイドは作成済み
5 件のコメント
Very comprehensive tutorial but 2 screws forgotten (on both sides of the viewfinder) and the adjustment thumb knob withdrawal before removing the top panel of the device. Good job anyway, tks
igloo - 返信
Is there a video of this?
Hubzilla - 返信
Removal of the sensor is NOT required to take the SD board out of the camera. The sensor needs to be fitted back to exactly the same height, otherwise you WILL not retain autofocus. Why was there no mention of this during the steps above?
Lee Gartside - 返信
Bonjour , ou peut on acheter le lecteur de carte sd , merci , cordialement
d007 Éric d007 - 返信
Step 19 and 20 are only for modifiing or replacing the image sensor
And is not recommended because AF doesn't work without further adjustment
Tom Oos Oss - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 67
今までの合計 9,926
